Can i bridge clutch diode??
pete_vfr
Post by pete_vfr »
Hey all track bike has failed to start and ive tracked it down i think to a faulty clutch diode (no continuity as haynes manuel test) anyhow my bike is for the track can i just bridge out the wires or is it needed for more then just saftey circuit as it apears to be? cheers
Bike owned: VFR400
Re: Can i bridge clutch diode??
Post by magg »
If you bridge out the diode and have retained the neutral lamp and clutch switch functions then the neutral lamp will illuminate every time you pull-in the clutch lever.
Does your bike start ok when the clutch lever is pulled in but fails to start when in neutral?
pete_vfr
Post by pete_vfr »
Hi Magg cheers for the info, i do have netral lamp im not sure i have the clutch switch anymore i will have to go check later, so it would not cause me any hastles or break anything by bridgeing out the diode wires? as i say its a track bike so im just keen to get it out there. i will go and check if i have a clutch switch or not is it on lever? cheers magg
