Nc30 cylinder layout/carbs
jak_d8345
Bike owned: Honda nc30 Honda nc35
Post by jak_d8345 »
Hi guys,
In the process of rejetting my carbs via the DIY guide in workshop thread. I'm fitting 118s in the front and 122s in the rear, what cylinders are classed as the front and which the rear as I think my carbs may be incorrect!
Regards jack
porndoguk
Re: Nc30 cyclised layout/ carbs
Post by porndoguk »
Front nearest front wheel,
Rear nearest rear wheel.
What exhaust system do you have fitted?
hunter
Re: Nc30 cyclinder layout/carbs
Post by hunter »
The rears are the one's r
closest to your wedding tackle.
jak_d8345
Post by jak_d8345 »
As I thought, my carbs are incorrect I have removed a 115 from rear left cylinder and a 118 from rear right cyclinder, emulsion tubes also incorrect! I have straight through standard system with free flowing end can!
porndoguk
Re: Nc30 cylinder layout/carbs
Post by porndoguk »
Have you had it dynoed or plan on getting it dynoed id say the jet combo your on would be adequate when installed right, you dont want the bike to rich or it will miss fire from over fueling and will cause damage.
