Front carburetor inlet rubber clamps
Hi all,
Apologies for the some what dim question but how do you tighten up the clamps on rubbers for the front carbs? I have looked in the Haynes manual but it doesn't seem to specify how you do them up...
I can obviously do the clamps up on the rear cylinder because there is easy access so no problems there!
Hope this makes sense and cheers for any help offered.
Re: Front carburetor inlet rubber clamps
The carb jetting document in this link shows how to access them, you simply need a long philips head screwdriver: http://www.400greybike.com/docs.htm
Thanks very much! The Haynes manual doesn't say anything about taking the lower fairings off to get the front carbs off!!
