Mph clocks
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Mph clocks
Post by V4beermonster »
Hi all I have a set of MPH clocks to hand question is are they restricted like the kph clocks? If so is it the resistor mod to over ride it?
Delboy
Re: Mph clocks
Post by Delboy »
MPH clocks should need no tinkering with...I swapped KPH clocks for MPH clocks and had no restriction :peace:
porndoguk
Re: Mph clocks
Post by porndoguk »
We had a batch of mph facias made to replace a kph facia so the reatriction would still be in place if someome has sold one on.
Rick
Re: Mph clocks
V4beermonster wrote:Hi all I have a set of MPH clocks to hand question is are they restricted like the kph clocks? If so is it the resistor mod to over ride it?
The restricton is part of the ignition unit and only on a Japanese ignition unit.
The trigger unit for the restrictor is what is in the Japanese spec clocks.
True UK clocks (not re-faced ones) don't have this trigger unit, thus no plug coming out the back. If you have a 3 pin plug then you have Japanese clocks that have been re-faced.
If your bike hasn't had the restiction removed via either a plug in box or connecting the wire to 12v (resistor mod.) then you wont have anywhere on UK clocks to plug your Japanese loom into so the bike wont rev above 10000rpm.
V4beermonster
Re: Mph clocks
Just looked there is a 3 pin plug, orange/blue,black/brown, and green are these uk or Japan clocks?
Cammo
Re: Mph clocks
Post by Cammo »
Orange/blue wire is the speed restrictor.
V4beermonster
Re: Mph clocks
So as I have the ignatech cdi fitted there will be no restriction?
Cammo
Re: Mph clocks
Post by Cammo »
Correct.
Re: Mph clocks
Neosophist wrote: If you have a 3 pin plug then you have Japanese clocks that have been re-faced.
As above, theres no plug on UK clock as that over-speed trigger unit isnt in the UK clocks.
If you post a picture up I can probably tell you who made the mph face.
And yes.. the igntiech ignition unit wont care about which clocks.
