loose end can - nc30
Spike16
Hi can anyone help with a bit of advice
Iv got a loose end can on my road nc30 its got a standard system with a scorpion end can, the stock system is cut just after the heal protector bit and the end can has a simple adapter that connects the two only there is only provision for an exhaust clamp on the end can end the other end is just a larger diameter no cuts to clamp to the system. the diameter is also a bit larger that the diameter of the cut standard system.
the result is the can is basicly help on by the exhaust bracket and strap and only located (not very well) at the bottom meaning the can can be moved by pushing on it. its not critical the bike as done at least 3k like this but its not ideal adn something id like to get sorted before its back on the road for summer
Any advice???
Any advice???
