restriction kit and speedo restriction help???? please
basmatti87
Bike owned: yamaha fzr 400 rr exup 1990
Post by basmatti87 »
hi there, airly new to the site, got fzr 400 exup 3tj maybe rr not quite sure,i was going to sell it but may be able to keep it thanlfully, i was wondering where any of you know where to get the gold speedo conversion kit, have found the blue one which i believe is no use to me to bypass this restriction. also my fzr has been previously restricted to 33bhp, i have located the kit is there any usualfull tips of removing theese easily as it looks like a bit of a job getting them out, thank you for your help in advance. will upload some pictures soon when i find out how to do so.
Re: restriction kit and speedo restriction help???? please
Post by Evilchicken0 »
The 3TJ RR has non adjustable suspension so the fork tops just have a nut type top - like these
The gold converters are harder to find but they do come up for sale just keep an eye out and ask in bike shops
basmatti87
mine is a rr then, not sure if is sp or any thing as dont quite know how to tell. thank you for your help fella.
It's and RR not an SP. The Sports Production is a variant of the RR intended as a base model for racing.
But is it black (faster) or white with dark red ??? pictures will help prove this :grin: :grin: :grin:
basmatti87
From what I can tell it has been sprayed. I not sure about speed as its restricted to 33 so unroll I can take them nasty little washers out I won't know. There is a picture of it on my first post on the newcomers bit, will put some more up wen am on laptop and not on phone.
Extra paint, slows them down ... it's the weight you see ;)
basmatti87
It could very well be lol. Have u any tips for removing washers. Have removed filter box and the carbs look awkward as hell to take out, any tips or suggestions would be appreciated.
I'd guess at taking the carbs off, but then you'd need to have them balanced and set up again because the mixture might be different
basmatti87
cheers evil. have managed to take the carbs off safely, nothing damaged and have removed the washers, didnt see the tiny clamps to start with and instead was trying to take them off at the manifold, all sorted, its surprised what a decent light will do with the fairing removed. think mine is just 3tj as its got it stamped pretty much every where 3tj-12338 or something along them lines. how do i go about balancing the carbs please?
basmatti87
this is what she looks like, needs abit of a clean up in some areas, obviously doesnt look like this currently
