NC30 jetting
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
NC30 jetting
Post by krisztian_andre »
From the state of my plugs, am I running lean, is it burning oil?
This is after riding the bike hard, then doing 14000rpm in a straigt, cutting ignition and pulling the clutch. The last few photos are from the front cylinder, the rest are from the rear:
https://plus.google.com/photos/11203432 ... gImq9J2gLg
Current setup is 118 rear, 115 front, full tyga exhaust with a short stainless oval can, K&N modded filter. Plugs done 4000km, engine 80000.
I'm having ocasional misfires(either caused by a faulty ignition system or oil on plugs I think) and there is a large flat band from 4500 to 7000 rpm.
I hope you can access the photos.
Re: NC30 jetting
Perhps a tad lean but wsnt your intake non standard
krisztian_andre
Re: NC30 jetting
apart from the k&n filter and the tyga system it's standard
krisztian_andre
Re: NC30 jetting
Cammo
Re: NC30 jetting
Post by Cammo »
Running standard jets with a full system and aftermarket system won't be great. On their website Tyga recommend somewhere around 120/122 jets with their system.
The midrange flatspot will be caused by the k&n filter. Swap it for a standard honda filter for best rideability.
krisztian_andre
Re: NC30 jetting
From what I read high humidity and high temoerature requires a leaner jetting. I'll try 118/120. What shoould I set the pilot screw to?
I bought 1mm washers, should I fit them?
Cammo
Re: NC30 jetting
Post by Cammo »
Check out the V4 jetting guide in the docs section. It answers each of your queries in this thread, and was put together for just that purpose:
http://www.400greybike.com/docs.htm
