17" rear NC30 wheels
Hanton31
Post by Hanton31 »
Does anyone know what other single bolt mounting wheels will fit on an NC30 without too much hassle and spending hundreds on nc35 ones??
Details would be a big help, as I'm building a race bike and getting close to desperate for a wheel
thunderace
Bike owned: R6, YZF600R
Re: 17" rear NC30 wheels
Post by thunderace »
I believe some Ducati wheels fit but I don't know what sort of work is involved.
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Either use the VFR750 wheel with rick olivers hub conversion, but its often just less stress and easier and not much more expensive to just buy a 35 wheel.
thunderace
Paul, does Rick's conversion change the VFR750 wheel to single nut fitting from the original four nuts?
JC120
Post by JC120 »
thunderace wrote:Paul, does Rick's conversion change the VFR750 wheel to single nut fitting from the original four nuts?
No it doesn't. It uses the 4 bolt pattern.
V4ia addict
StrayAlien
Bike owned: NC30, Dukes, Hog
Post by StrayAlien »
The best option is just to get the NC35 wheels. There may be others about that fit the single nut axle but they'll be more expensive. The VFR750 wheels are heavier (and not that much cheaper than NC35 wheels) and you'll need either the RO axle mod, or a modified VFR750 axle.
For racing. Easiest to buy the NC35 wheels. My $0.02 worth.
jimmytanko
Post by jimmytanko »
old thread revival batman
but looking into getting a 17" rear wheel and wondered if anyone knows of other wheels than NC35 or VFR750 that can fit or be made to fit?
please :)
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Post by jim157 »
Bros 400 17" rear, MC28 rear (same as NC35). Ducati rears can also be made to fit with some modifications.
AUTOEXEC.TWAT
jimmytanko
thanks jim
