Which clutch levers are 100% changeable For the NC30
matty_boy
Bike owned: Fitness bike
Post by matty_boy »
Ok i am after buying a Pazzo/CRG clutch lever but no one can find a match on the list.
If you have a look on the link you can see what models they stock, any one know if any are the same as the NC30?
http://www.cmcbikes.com/shop/product_in ... b85ae88d10" onclick="window.open(this.href);return false;
I am thinking that the Honda CBR900R 93-99 should do the trick ?
Any info would be ace, Ta Matty.
Smev
Bike owned: NC30 of course
Re: Which clutch levers are 100% changeable For the NC30
Post by Smev »
I'm looking to get one as well - just the clutch lever as I have a brembo radial brake master cylinder.
Mister Donut Rep NC30
RickOliver
Post by RickOliver »
Matty - This is the definitive list from the Honda EPC.
CBR600FH - F3 (1987 - 2003)
CBR900RRN - RR1 Fireblade (1994 - 2001)
VFR400R NC30 (1989 - on)
RVF400R NC35 (all)
BTW, did you get a steering damper - I have new 140mm stroke Sprints & fitting kits in stock.
Your caliper kits should be here today...
matty_boy
Post by matty_boy »
Thanks for the info Rick i am off to order them now.
I will give you a call later and have a chat about the dampers.
TA matty.
