rvf 400 nc 35 wiring route
mxcooper
Basically i need as much info as possible on the route my wiring harness need's to take. im in the process of building an nc35 .
i can upload picture's etc etc to the forum?
does anyone have a manual i can download
if anyone could shed light on this by picture's or something id be very grateful.
Thanks Mitch
Thanks Mitch
- speedy231278
Re: rvf 400 nc 35 wiring route
My bike's in a zillion bits, so I could take some pics at the weekend, however, very roughly, most of the switchgear plugs into the end of the loom where the reinforcing tube goes between the sides of the frame just underneath and behind the headstock. The loom goes back along the right side of the bike (as you are sat on it). There's a bendy clip mounted on the side of the cover for the crankcase breather on the rear head. When you get to the starter solenoid and battery connector, it then goes across to the other side of the bike, and it then runs along the subframe rail to the fuse box. There are some clips on the underside of the subframe where the loom crosses sides, and I seem to recall it runs in a channel up the side of the undertray, although that might just be the tail end where it goes to the rear lights and indicators. I'll check at the weekend unless anyone else can come up with a quicker answer.
get the service manual for the NC30 from the document section and use that - job jobbed.
