Master cylinder identity??
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster »
Hi all just about to order a repair kit for my front master cylinder, all the kits listed for the nc30 are 12.70mm OD. But my road bike one is stamped 5/8. And this one is stamped 14? Any ideas ?
Re: Master cylinder identity??
14mm is std NC30 m/c size
5/8 is better used on the lager Nissin calipers, or the brembos
not sure where the 12.7 is - I have not replaced these seals on my bike, which is a surprise to me.lol
V4beermonster
Right that's good to know will query it
V4beermonster
Does anyone know the correct dimensions?
speedy231278
Post by speedy231278 »
Maybe it's the internal diameter of the 14mm seal?
speedy231278
Looking at the dimensions listed here, I wonder if it's actually the diameter of piston? You'd need some clearance between the piston and the bore to allow for the seal....
http://www.stuff4bikes.co.uk/front-brak ... 2521-p.asp
V4beermonster
Just checked the bore of the cylinder it is 14mm OD any ideas
thunderace
Bike owned: R6, YZF600R
Post by thunderace »
V4beermonster
Here
V4beermonster
Ok David silvers just checked the sizes, standard nc30 kit is 14mm OD x 50.5mm so don't know what they are selling on ebay
