Swingarm installation
				avinitboys
- Bike owned: TRE NC24 NC30x2 GK76a KTM250
Finally I'm ready to start putting the old girl back together after weeks of powdercoating and plating.
Not sure of the method to install the swingarm. Can someone run me through it and give me a torque setting for the locknut and end bolt?
While we are on the subject of torque settings, I've had a look through the site and can't seem to get a definitive quide for anything on a 76a. Do any of you have a list or something from the jap manual? Anything at this point would be appreciated otherwise I fear a long and stressful rebuild ahead wondering if things are done up tight enough or, whether I'm gonna strip threads!
I'll get some pics up when I get a minute.
Cheers in advance
Paul
Cheers in advance
Paul
				donk
- Bike owned: Gk76a x2
Re: Swingarm installation
These are some of the torque settings I have for the 76a I got them from variablevalves and stripes I think they may have a jap manual.
Swing arm 85-115nm
Top yoke nut 50-80nm
Head bearings40-50nm
Rear wheel spindle 85-115nm
Front wheel spindle 50-80nm
Front spindle pinch bolts 20-31nm
Hope this helps mate
						Swing arm 85-115nm
				avinitboys
Cheers for those. Much appreciated
				avinitboys
Anybody else  ?
Really stuck on this swing arm! How far does the externally threaded castle nut need to screwed in? Does it just need to take up play before tightening up the locknut or does it need to be torqued?
 ?Really stuck on this swing arm! How far does the externally threaded castle nut need to screwed in? Does it just need to take up play before tightening up the locknut or does it need to be torqued?
- vfrman
- Bike owned: NC30, 1098s
Do you have a Haynes manual?? What does it say?  IIRC if there is a torque for the threaded spacer against the bearings, but it will be very small.
I'll have a look at my manuals tonight when I get home from work and see if I can find anything.
				avinitboys
If only life was that simple!!!!
The only manuals available for a GK76 are rare, expensive and printed in Japanese. These things are an absolute nightmare to own. Information from anybody is scarce probably because everyone's scared to take anything apart, because they don't have any information on how to put it back together
I'm going off to sulk and work on the NC30's. At least I can drool over the Haynes manual and the lengthy list of torque settings
- vfrman
LOL!  My bad.  When I was looking at the new forum posts I didn't notice that this one was in the GSX-R forum.  GL!
- Variablevalves suck
If it is the type with a castle nut and central hex you can use rgv250 manual figures.
http://www.rgv250.co.uk/forums/index.ph ... 50-manual/
If the link works you can then click on the manual link and go to later additions 'm' onwards and will find a picture plus torque settings.
				avinitboys
Cheers for the link. That's without doubt the most useful information I've come across. The vast majority of it seems like it translates across to the GSX'Rs. I can get cracking now, no excuses!
