cam timing
mpotnoodle
cam timing
Post by mpotnoodle »
i am in the process of building my engine as it was in bits previously i just need to check i have set the timimg correctly:-
the line with the t mark next to it on the flywheel is in line with the crankcase joint at the front of the engine,the camshaft dots line up with the little dots on the camcaps and the camshafts face away from each other while no1 piston is at top dead centre.my question is do i have to set any ignition timing or does it know when the camshafts are facing away or towards themselves for starting purposes
cheers mike
Re: cam timing
Post by Evilchicken0 »
The holes on the cams line with the spots on the cam caps. The spots are on the right hand side of the engine with the exhausts faceting you.
The flywheel only fits on in one place and the woodruff key locates it. The timing is taken off the flywheel.
Turn the engine over by hand, if it stops don't force it
mpotnoodle
Re: cam timing
when you say the holes do you mean the ones on the outside face or the ones on the edge(look like centre punch marks)these are the ones i have used and it turns over fine
thanks mike
Re: cam timing
Yes the center punch marks.
Sounds like it's good to go.
mpotnoodle
Re: cam timing
thanks everyone for you help i thought it was right but better to double check while the engines out hopefully i`ll get the old girl back together over the next few weeks and organise some pictures
mike :smile:
thunderace
Bike owned: R6, YZF600R
Re: cam timing
Post by thunderace »
You think that was difficult? ;) Try it on a 12 cylinder Volvo Penta industrial engine after a rebuild (there's four heads for a start!). I did one this week at work and it took ages :(
dobbslc
Re: cam timing
Post by dobbslc »
Your not Guy Martin are you? :grin:
