Rear hub problem NC35
Posted: Sat Jan 19, 2013 6:17 pm
Hi All,
Just in from what I thought was a great day in the garage if a liitle cold. Got the steering head bearings replaced fitted the newly coated instrument bracket and re-sprayed top yoke.
Replaced the bearings in the rear hub all spinning nicely. Re-fitted, it got the hub nut on and torqued up and hub is frozen.
Bugger thinks I, what have I done wrong, took rear caliper off to make sure it wasn't this ......no hub still locked.
Let off hub nut and hub spins. Think to myself perhaps I over torqued it (200Nm) as per manual so loosen it off, hub spins but as soon as you torque it even over 80Nm it locks.
Used Wemoto bearings and Honda hub nut.
Too cold and knackered to think anymore about it now.... time for a beer.
Gav
Gav
