Bike not starting
Bike not starting
Hey guys,
I just picked up a VFR400R track bike.
It is quite poor cosmetically but when it was running when i first got it. It idled well but then i took it out for a ride and it eventually died and wouldn't start again.
What are the most common causes of it not starting?
Cheers for advice
Cheers for advice
- speedy231278
Re: Bike not starting
Loads. You're going to have to be a little more specific on how it died, and what it is/isn't doing when you try and start it. Could be anything from a lack of fuel, dodgy ignition circuit, blown fuse.... all sorts. However, if something's gone wrong, someone here will have had it happen, so an answer should be forthcoming! :-)
- spenceley1
- Bike owned: CBF500-NC30
If it was running well but died when you was out first point would be check fuel but as speedy said, could be so many things...
