Where should this wire go?
jetblack
Bike owned: '89 NC30 SEED
Post by jetblack »
Hi, I fitted my new rads today and whilst i was doing it i spotted a wire hanging loose!
Anyone know where this should go?
Its on the left side of the bike near the coil pack and is connected at one end to an earth point and the other end, with a ring type connector on the end, is just hanging. I'm marked on the photo where it is and where its hanging.
please note the other 3 wires black coming from the earth point are my RO Earthing kit- they are not standard issue so please ignore them for the purpose of this query!
Any help appreciated.
thunderace
Bike owned: R6, YZF600R
Re: Where should this wire go?
Post by thunderace »
Is it the earth for the temperature sender? Sometimes they have a bolt on earth instead of earthing to the frame directly.
jetblack
Post by jetblack »
Dont think so, i've reconnected the temp sender wire to the sensor and the temp gage appears to be working correctly.
bikemonkey
Post by bikemonkey »
The sensor on your rad isn't the temperature gauge, it's your rad fan switch.
It could be your rad fan's ground.
NGneer
Post by NGneer »
Some people have put a direct path to earth on the rad fan (normally switched) so you can turn it on at will and not wait until the thermostat cuts in. Handy for when you know you are heading into a bit of slow town riding....might be cable from that.
If the bike runs fine and everything functions as advertised.....I wouldn't worry too much ;)
Looks like an aftermarket earth lead.
Either to improve the earthing or something else was using it at one point, perhaps an alarm etc.
I would just remove
--Edit--
Just noticed that it has the full set of extra earth leads installd.. the only stock earth on that bolt is the one that isnt black.
speedy231278
Post by speedy231278 »
It's not for the rad fan (or at least, not standard), the rad fan earth lead is terminated on one of the rad fan mounts.
If this lead isn't connected to anything else and all your bits and pieces are working correctly, then I agree with Neo, take the thing off, it's just a leftover.
royster81
Post by royster81 »
Rad fan earth
