GPZ400 piston rings
nikhlitschek
GPZ400 piston rings
hi!
recently I registered on this forum, but I been reading some time before.
I need a little help, I looking for gpz 400 piston rings, engine ZX400DE-040766, a friend mine told's me this item are discontinued, this is true?, do you know about aftemarket replacement?
regards
Bruno
sorry for my english gramma
regards
Bruno
- thunderace
- Bike owned: R6, YZF600R
Re: GPZ400 piston rings
They are. Your bore (assuming it's the GPZ400R IL4) is 55mm. About your only option is to over-bore and fit 57mm pistons from a ZXR400, just bear in mind the ZXR has a 3mm shorter stroke. Or just stick a ZXR400 motor in.
nikhlitschek
thunderace wrote:They are. Your bore (assuming it's the GPZ400R IL4) is 55mm. About your only option is to over-bore and fit 57mm pistons from a ZXR400, just bear in mind the ZXR has a 3mm shorter stroke. Or just stick a ZXR400 motor in.
thx men!
