nc23 electrical problem (headlights on = misfire)
willpisme
Bike owned: NC30, R1, CB250RS, FZR400
Post by willpisme »
Hi, as i said in the title my nc23 has started to seriously misfire with the headlights on full or dipped beam. It runs sweet as a nut with just the sidelights on or with them off.
It seems to run a little better with one of the lights disconnected.
My worst fear is the alternator going but thought i would ask on here in case anyone else had the same sorta thing happen?
Cheers for any advice
Will
dunkenb
Regular Member
Bike owned: Cbr400rr nc29 type8 NSR250
Re: nc23 electrical problem (headlights on = misfire)
Post by dunkenb »
How olds your battery?
willpisme
Post by willpisme »
the battery is about 2 months old
Aye, does seem like as soon as the lights start to draw then the bike suffers. Got to be worth checking your generator output and reg/rec health too.
I suspect you'll find a knackered genny...
blueflag
Post by blueflag »
I have a genny or two if you need one.
First off, check the voltage across the battery terminals when it's running.
willpisme
Post by willpisme »
thanks, ill get the multimeter on the battery soon as possible and report back with results
EDIT: If i run the bike with one headlight disconnected it runs completely fine
