NC30 big valve mod
twist&go
NC30 big valve mod
has anyone heard of or seen a nc30 fitted with bigger inlet and exhaust valves????
a local racer who runs a nc30 tells me that hes running bigger valves both In and Ex its a self tuned motor and hes done all the work him self.
so is he feeding me total shite or can it be done
any advice on the matter would be mega
- vfrman
- Bike owned: NC30, 1098s
Re: NC30 big valve mod
I'm gonna call BS on that one. The valves are already pretty crowded in the head. Bigger valves would take a lot of work, and probably a re-designed head.
- Yakama
As Tony he spoke to someone recently who had fitted bigger valves
I have this from Chris at Dynopro..
motor strip build £450
new gaskets £86
piston kit £575
rebore £150 (dont worry about the liner thickness there is enough left if done correctly)
machine pistons weight match etc £125
suggest re shelling motor at this point £130 ish
additional work
tuned heads that work £250 inc shims and cam shimming etc
reduce weight and balance cam idle gears £150
adjustable cam gears £250
flow crank cases incorporate extra breather £125
blue print gearbox and modify clutch £100
1mm oversize valve kit inc seat adjustment etc £350
new gaskets £86
piston kit £575
additional work
- VFRkieran
Hasnt the g force motor got bigger Ti valves too? Must admit it does look like a proper squeeze in there for anything much over 1mil.
£86 for a gasket kit, that's cheap
- JC120
- Bike owned: NC30 NC35 RC30 RC45 MC22 NXA
There's a local mechanic named Jim Granger who's fitted some. The valves where custom made and took a few batches to get right. He mostly works on RC30's but does work on the 400 v4s too. I got to check the valves out in person. I believe they're the same spec as the gforce ones.
V4ia addict
