NC29 Battery
- Bike owned: NC29 Import-ZZR600
NC29 Battery
My battery has given up the ghost , (it was a cheapy!!!)
Can anyone give me some advice what I should get and where do I get one from?, the bike doesnt get a lot of use but was started regularly NC29 1991
- thunderace
- Bike owned: R6, YZF600R
Re: NC29 Battery
YTX7L-BS. Varta are a good lead acid type and you should be able to pick one up for under £35. If you're splashing out, try £80 for a Lithium one from M&P.
- Davez29
- Bike owned: NC29 forever
Re: NC29 Battery
I can vouch for Varta agm as being brilliant but also a cheaper Lucas agm sounds and feels like it has a better CCA or Cold Cranking Amps than the Varta from my daily use. Starting just sounds more powerful in the Lucas.
In my battery drain post i mentioned I was using a Yuasa, i meant Varta but I have heard Yuasa are made in the same factory and are also good.
Re: NC29 Battery
Graeme France - GF Racing UK
UK Warehouse 01652 650142
GF Mobile 07778 628448
email: gfracingtw@live.co.uk
http://www.gfracinguk.com
- royster81
Re: NC29 Battery
Just to 100% confirm the correct standard battery
for a gull arm nc29 is a ytx7l ?
