HRC Temp gauge
jb1000rr
HRC Temp gauge
To all you HRC experts out there.
Where does the temp sensor, that's attached to the other end of the long lead on the HRC temp gauge, fit into the coolant system?
The sensor appears too long and too large a diameter to fit into the thermostat housing where the standard sender is located. I did see a thread from Martin, where his father fabricated a housing for the HRC sensor to fit onto the front left hand side of the upper rad.
It doesn't appear to give any guidance in the NC30 HRC manual as to where the sensor fits into the coolant system.
The only guidance I can find is in the 1991 RC30 HRC Kit Manual, that says: to use the HRC Water temp Gauge you use Adaptor, Water Temp Sensor 19301 NC7 000.
Does anyone know where Honda Racing expected the sensor end of the temp gauges long lead to be fitted and/or what the RC30's adaptor looks like or where that was fitted?
Any help on any of the above appreciated.
Re: HRC Temp gauge
Im 99% sure it goes where martin has his, the HRC rads have provision for this. I have a RC45 HRC temp gauge here which has the same sender unit but its fixed to a alloy T piece which is spliced into a water pipe.
jb1000rr
Re: HRC Temp gauge
I've just had another look at the NC30 HRC Manual on Block No F7 and it looks like there might be provision for it on the very top of the upper rad on the left hand side as you look at the image. It's only an educated guess though and of course you need original HRC rads!!
I like the sound of the alloy T piece spliced into a water pipe though that saves drilling holes in good rads and whilst Martins solution worked I did wonder how he got on re-fitting his side and front V panels?
Is there any chance you could post a picture of the RC45 solution?
lukemillar
Re: HRC Temp gauge
Boom - thread bump!
Anyone know what the thread size and pitch is? I'm pretty sure it is M18x1.5 but would love someone to confirm as I don't have my gauge handy to check
Luke
Luke
richyrd5
Re: HRC Temp gauge
Yes 18x1.5 and can fit into fan switch thread(some aftermarket rads have this size,as mine does)...
- Yakama
Re: HRC Temp gauge
That's correct ive got HRC rads and it fits directly into the top rad if I remember correctly will try and get a pic for youjb1000rr wrote:I've just had another look at the NC30 HRC Manual on Block No F7 and it looks like there might be provision for it on the very top of the upper rad on the left hand side as you look at the image. It's only an educated guess though and of course you need original HRC rads!!
How about the attachment in this pic of an HRC temp gauge on ebay:
http://www.ebay.co.uk/itm/HRC-RS-NSR-CB ... SwKtVWyBPe
and the attchment:
https://translate.google.co.uk/translat ... rev=search
lukemillar
Re: HRC Temp gauge
That post just made my week! Cheers for the link - just ordered the pipe from weblike
Luke
Luke
- DAC
- Bike owned: 89 NC30
Re: HRC Temp gauge
Yep, just like the one I made from a 22mm plumbing Tee piece and a brass nut.Yakama wrote: How about the attachment in this pic of an HRC temp gauge on ebay:
and the attchment:
I'll try to find a picture and post it up here -
If you zoom in, you can see the Tee piece.
The HRC sensor is screwed into the horizontal arm on the RHS behind the fairing.
... like this ...
Regards,
Dave.
RWB NC30
