Pink wire ??
Pink wire ??
Help needed with an H1 model I'm stripping for track use. What does the pink wire on the speedo do?
Is it something to do with the restriction?
I could also do with a wiring diagram is there any around on the forum?
Thanks folks.
Thanks folks.
- Bike owned: ZXR 400 L4, FZR 1000 EXUP '89
Re: Pink wire ??
yes, its the wire that goes from the speedo restriction to the CDi, put a (i think) 100ohm resistor in place of the clock and you will be fine...ive got a UK-spec L-model so i dont have any restriction issues.
