Nc30 gear change issue
V4beermonster
Bike owned: Vfr400,gt750,vfr400/750cc
Post by V4beermonster »
Hi guys bit if a weird 1 I've noticed the last few weeks the bike has started to seem harder to select gears, when I say harder I mean more force needed still goes in ok just with more of clunk. Not sure what it could be but even my mate said was fairly hard to get in gear. Bike runs like a dream oil level is fine. Clutch is good not dragging. Anyone got any ideas??
porndoguk
Re: Nc30 gear change issue
Post by porndoguk »
you may have the clutch cable a little too loose,
or try moving the pedal position and or moving the clamp on the gear selector shaft by a spline forward of back of the staked dot. mines a bugger to change but its a case of fine tuning to find what suits you best.
V4beermonster
Mm cheers for reply, it seems to have only just started so how, was easy to change at first any ideas
porndoguk
Post by porndoguk »
tlnut wrote:Mm cheers for reply, it seems to have only just started so how, was easy to change at first any ideas
Cable may have stretched, or the adjusters may have vibrated loose not uncommon bud.
