steering head bearings
stimpy
Post by stimpy »
my 23's head bearings have seen better day
so im up for replacements..
any1 got the part number for the taper style bearings??
cheers
stimpy
leopard_pagan
Bike owned: used to have a NC29
Re: steering head bearings
Post by leopard_pagan »
do you have a chance to remove them 1st?
if so take the lot to any decent bike shop/bearing shop so they can match them up for a new set, then write down the part numbers in the manual.
mine cost me £25-30 5yrs ago. NC29
rob
Post by rob »
here you go http://shop.wemoto.com/pictures.dyn?u=25324qqq25618" onclick="window.open(this.href);return false;
stimpy
Post by stimpy »
cheers rob n LP but im just after a part number cause i can be alittle lazy.... i might just have to pull the bearings out(of the 23 and 29) and head down to the bearing shop lol
stimpy
leopard_pagan
lol.. getting them buggers out isnt the lazy way to get the part numbers.
cant remember IF the micro fiches have the dimensions on them or not.. i'll have a look when i get home.
trickyd400
Bike owned: NC23 x3, NC29, Beta & NC31
Post by trickyd400 »
Hi, Stimpy, just been and got the set I've recently won on fleabay. the boxes are not branded, but have numbers 324706 on one and 325505 on t'other. They are made in Japan, but are not Honda. you'll need to be careful you don't bu**er up the dust seals as they are not usually included. The bearings measure as follows:
324706
markings: MCI JAPAN 3200SX (on outer ring) and on the other side: 26 (on inner ring)
ID 26mm
OD 47mm
depth is difficult to measure because the cage protrudes beyond the bearing rings 15.5mm
325505
markings: MCI JAPAN 32006JR (on outer ring) and on the other side: 32006JR (on inner ring)
ID 30mm
OD 55mm
ID and OD are nominal and the box and contents could have been swopped, but this should help (I hope) :!: :geek:
stimpy
Post by stimpy »
trickyd your the man!...thank you very much
stimpy
