nc29 ram air system
nc29 ram air system
alrite lads n ladies... new to the site! im converting my bike from race back to road.... its got a RAM air system in it and big jets, so i was just wondering would i NEED to put an original air box n new jets in? any help would be appreciated.. cheers
- Bike owned: Honda NC29
Re: nc29 ram air system
Hi
Most guys run K&Ns with the jets up-rated. so the short answer is no.
However, if you want to take it back to factory, you'll need to down jet it. (unless theres an aftermarket exhaust. The engine might need more fuel to balance the backpressure from the exhaust, check with the manufacturer of the exhaust)
Hope this helps
PS welcome to the site :)
Hope this helps
ill leave it as it is then... cheers mate
- leopard_pagan
ram air is no good on the road. subject thats been covered several times in the past
swap the air box for a OEM one, pop a OEM or K&N in it and you will have to get it all re-tuned.
sell the ram air/jets on flea bay/400GB to help pay for the tuning....
rule of thumb.. if you change the air filter and/or jets and/or end can/headers
your safest bet is to get the bike re-set up for what you have just changed.
i'll swap it for a standard one!!
is the ram air system bad for the bike when just bein used on the road? dont understand... is it not just like th SRAD?
swap wot the bike or ram air?
the ram air system and the jets for a standard one with a decent filter??
its not much of a ''system'' just 2 hoses goin from the top of the box into some sort of link feed goin to the carbs.... hard to explain ill take a pic of it.... il prob just plug the holes or somthin...
well if you want i'll swap you for a standard because the you wont have to??
plus i can check out what this ram air is like and see if i can develop something from it for my race bikes
chris
chris
- Bike owned: CBR125, NC29, VFR400, CBR900,
ram airs no problem on the road, it only kicks in at 50-60mph friend of mine runs his on a day time mot with no problems?!
hope this helps
