Question on main jets .........
SilverSurfer
Post by SilverSurfer »
Hi again i have removed my carbs on my nc30 and found that all the mainjets are 106 (Front and Rear).
Now my question is if it can cause the bike to struggle when accelerating and at topend. it seems like it should be faster :? but it`s like i`m on a 125cc when punching it :x does anyone have a answer?
bikemonkey
Re: Question on main jets .........
Post by bikemonkey »
Definitely should not be 106's, they were 115 front and 118 rear as standard.
Someone may have had a restrictor kit in there before you had the bike and re-jetted to suit.
That's very lean.
VFRkieran
Post by VFRkieran »
That is really lean! Even the k model NC30 ran 110's as stock and that is considered to be too lean.
porndoguk
Post by porndoguk »
VFRkieran wrote:That is really lean! Even the k model NC30 ran 110's as stock and that is considered to be too lean.
+1
whack some 115 in the front and 118 in the rear,
having said that after a recent dyno trip there is no difference in temps and air fuel ratio between the front and rears and is fine to run all 4 the same,
v0latile
Bike owned: nc30
Post by v0latile »
porndoguk wrote: +1
i run 118/120 is it worth changing to 120's all round when I next have my carbs off. I run standard with a straight through can.
Before you go ordering jets you might want to confirm you actually have nc30 carbs fitted and not nc35 carbs which run 108's as stock. Ok 106 is still low but if your jetting for 30 carbs when you actually have 35 carbs your wasting your time and money.
You may also need to take into account you live in SA, the jetting advice your getting here is based on UK weather and altitude and that may well be different to where you live, any other SA NC30 owners on here?
SilverSurfer
I think they are nc 30 carbs coz the part that you have to remove to get to the needles are metal and not plastic like the nc 35 carbs, the funny thing is it doesn`t struggle to start at all even in cold weather (without choke), it`s only when punching it that it`s weak.
You definitely need to factor in altitude....where in Saffa are you?
If you are up on the plains in Jo'burg Pretoria area then that is pretty fecking high so you'll need smaller jets.
Best bet..get it dyno tested and see what the air fuel mix is like.
If you live on the coast and bought it from up there..it will need changing.
speedy231278
Post by speedy231278 »
SilverSurfer wrote:I think they are nc 30 carbs coz the part that you have to remove to get to the needles are metal and not plastic like the nc 35 carbs, the funny thing is it doesn`t struggle to start at all even in cold weather (without choke), it`s only when punching it that it`s weak.
Not only that, the air screws on the NC35 carbs are underneath and the float bowls are shaped around them. They are on the side on the NC30, so the float bowl doesn't have the recess. That's a fun place to leave the flaming things for us NC35 owners, as if having three balancing screws underneath wasn't bad enough!
SilverSurfer
i`m in the north west province 100km from Pretoria, so what ur saying is that 106 should be fine for where i am? or should i go ahead and change them to STD jets?
