1wg brakes
stephen918
- Bike owned: fireblade , cb250n + fzr400 1w
1wg brakes
rebuilding a fzr400 1wg genesis and having a problem with the brakes , its got the 2 piston calipers which i presume is correct but when i try to mount them on the forks with the wheel in place and pistons pushed back they dont seem to fit behind the mounting points on the forks , is there any other front wheel that fits but whos hub centre is wider
rockTJ
Re: 1wg brakes
Pics would help! Have you had the bike on the road before?? Have you got the right discs on the bike??? 1WG discs are not offset if I remember rightly??
Chris
Chris
- thunderace
- Bike owned: R6, YZF600R
Re: 1wg brakes
Have you got the forks in the right sides? They each fit both sides but the caliper mounts are offset.
stephen918
Re: 1wg brakes
not had the bike on the road and bought as project so its a bit of an unknown , the forks have no oil in them so chances are that they have been off so the forks on the wrong sides sounds like the one so will probably give that a go first , cheers for the help fellas
Re: 1wg brakes
The front spindle goes in from the throttle side.
stephen918
Re: 1wg brakes
forks are right way round so can count that out , dont now if this is right but its only got 2 piston calipers that look very much like the rear brake
Re: 1wg brakes
Yes it sounds like a Genesis model - twin headlights and no air intakes
Are the calipers on the correct fork leg, try swapping them over.
The bolt spacing should be 83-85 mm on those. If they're 100mm then they might have been swapped for FZR600 legs.
willandrip
Re: 1wg brakes
You have got offset discs on non -offset forklegs or vice versa .
Seen loads of discs up for sale lately as owners bought correct dia disc but wrong offset ,your P.O probably did same !!!
- Kayla850
- Bike owned: Sunn Tzar S2
Re: 1wg brakes
I've got a pair of Genesis (no offset) discs spare here if they're any use?
www.projection-racing.com
www.pjcfasteners.com
stephen918
Re: 1wg brakes
right yes it is a genesis and the discs do have an ofset , are the genesis discs complitly flat cos if they are then i need discs
