Front master cylinder
Noodles
Bike owned: GSXR1000K3 NSR125 CBR400NC29
Post by Noodles »
Do all NC29's have 1/2 inch front master cylinders?
Mine doesn't look like the original, it has 14 marked on it instead of 1/2.
The brakes seem to be very wooden, just wondering if this is the problem.
tfr125
Bike owned: VFR 400 NC 30, ZXR 400
Re: Front master cylinder
Post by tfr125 »
14mm is the standard NC29 master cylinder. If the brakes feel wooden you most likely have seized piston/slider/pad issues.
I run standard master cylinder/pads/discs on my NC29 race bike and you can stand it on the front wheel with just two fingers :!:
1/2" is VFR/RVF standard fit.
tfr125
Post by tfr125 »
Oops edit last post - just checked on my bike 1/2" diameter IS standard on CBR400NC29 - 14mm is VFR/RVF NC30/35 standard fit.
Apologies for the duff information :oops:
Noodles
Post by Noodles »
Cheers mate, looks like a swap will sort the problem.
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti »
Noodles wrote:Cheers mate, looks like a swap will sort the problem.
Yes, should do.
