£17 quid a bulb!!!
				fzr6
£17 quid a bulb!!!
my regulator blew the other day taking both my headlight bulbs out.
so not only did I get stiffed for a new regulator but both headlight bulbs at £17 bloody quid a piece!
not looking to get ar*e raped again in the near future.
anybody managed any sort of mod to fit h4's as this would offer both better prices and more lighting options?
muchos grumpy
muchos grumpy
				fzr_nut
Re: £17 quid a bulb!!!
Yep change the headlight to one from an fzr 600.
It mount's up the same and use's h4 bulbs.
I did it on my 3tj work's a treat.
				Marb
- Thieving Pikey Twat
If you have an 3EN2, get a set of headlights from a EU FZR1000 89/90. Exactly the same and you can fit H4
Is the FZR600 head light twin paralever like the TJ ???
				Marb
Twin Paralever?
				fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
No, there are 2 types of fzr 600 lights. The 93 on model has just one "paralever" as you call it ( didnt know it was called that) and the earlier ones (1992) are a conventional headlamp which has a sidelight in it (93 on had a seperate sidelight above the main light). I have a 93 FZR600 with the 92 light fitted. It cost £5.Evilchicken0 wrote:Is the FZR600 head light twin paralever like the TJ ???
				fzr6
go on then I'll bite.
whats a paralever?
						whats a paralever?
Paralever are the 3tj type I thing the lens or bulb move in order to focus the lights. Like the small endurance race lamps
				fzr6
okay, think it must be the lens that moves then because the bulb is definately fixed position.
I've been looking at this today with a view to knocking up some sort of an adaptor that will let me run h4's without changing the original light unit.
this will give me the option of running 60/55w if I want and give me a good selection of quality bulbs
also should I have a bulb go in future I can easily get a replacement at pretty much any garage for about £4 rather than having to order them in special, wait days for them to turn up and get wallet raped when they arrive!!
				sharpey
will cost 300quid but upgrade ya headlights to HID, or you could try high level they do cheap chep parts, as do bike it.
