NC30 HRC ignition module?
RandomDan
Iv got a HRC ignition module and i want to know more about what it actually does.
http://www.google.co.uk/imgres?q=vfr400 ... s:44,i:222
One of these.
Also whats one worth these days?
May have to note it on the insurance if its alot!
One of these.
Re: NC30 HRC ignition module?
£50-100 depending on where you sell it.
It does nothing to performance just removes speedo restriction. Its been proven on the dyno by myself and kev.
RandomDan
It does smooth the ignition timing out a bit though mind you.
you can actually hear the differance, was just wondering if there was anything more significant.
there are dyno graphs somewhere on here with the difference against stockRandomDan wrote:It does smooth the ignition timing out a bit though mind you.
Edit: the difference between stock cdi & stock cdi with the HRC SP unit plugged in, hardly anything, on a later test it made a loss.
viewtopic.php?f=24&t=34600
