HRC Overflow
- iDemonix
- Bike owned: '92 NC30
HRC Overflow
My NC30 has been spewing out water when it gets hot lately and covering the RHS of my fairings in white powdery water substance. I've started stripping the bike and discovered that the rubber pipe from upper rad to expansion tank had a split in it, I tried pulling the hose off the rad and it split in half.
So, what's the point in the HRC overflow mod? Where do people put the bottles? Is there any difference apart from a few grams of weight saving? Also, I assume that water can flow too and from the expansion tank, but with the overflow mod it can only flow to it, meaning if a lot of water ends up in the bottle, have to refill the rad?
- iDemonix
Re: HRC Overflow
D'OH.
Well, looks like I need a new upper rad. Annoying as it'll take me a while to save up so looks like I won't be attending the 400GB meet up at the moment
- speedy231278
Re: HRC Overflow
I'd see if you could get that welded if you have a friendly workshop nearby. Unless the rest of the thing is really scabby....
- iDemonix
Re: HRC Overflow
It's hit the deck at some point so the other side is bent as buggery, so might be worth getting a new one, depends what they fetch?
- bikemonkey
Re: HRC Overflow
If you can't get yourself a new one I have my old set for sale which are usable and all intact?
You might just have to swap the rad cap over though (mine's a bit funny).
- iDemonix
Re: HRC Overflow
How much do you want for it matey and are they in good condition? If they're a bit tatty I might just shell on a new set, let me know.
- bikemonkey
Re: HRC Overflow
http://400greybike.com/forum/viewtopic. ... 0a8074cd73
They're in my for sale thread.
I can split them and you just take the top if you want, I'm sure someone on here or eBay might want just the bottom.
Only problem with the top is the rad cap is pretty tired, it was held down with a bit of gasket goo when I got the bike.
