Float heights, have i gone mad???
Right its been a while since ive done the float heights on a NC but not that long. Ive got the float just resting on top of the needle valve without depressing the needle, got my float height setting tool cut to 6.8mm for RVF carbs and resting it on the gasket face the float height measured about 15mm! So float out and bent the tab to get it down to 6.8mm but the floats hit the deck at about 7.5mm.
Double and tripple checked im doing it right then got a spare set of RVF carbs out that im certain i set the heights on before i stored them away, opened them and there nowhere near 6.8mm!! Someone please tell me ive missed something obvious.
- speedy231278
Re: Float heights, have i gone mad???
Yep it isspeedy231278 wrote:Isn't it 12mm for a 35?
Edit: no, it's 12.5mm
Thankyou
- speedy231278
Any chance of posting a few pics of how to use the gauge? I still can't get my head around it. Do you hold the thing at 90 degrees to the float chamber and gradually tip the carb until the fattest part of the float is touching the gauge, and at that point the lever on the end should *just* be making contact with the valve?
No, tip the carbs on their side and obverse the way the float needle works, with the needle resting fully in its seat tip the carbs slightly so the tab on the float makes contact with the pin on the needle valve. Now place the tool on the float bowl face so the 12.5mm cutout covers the float at the highest point, it will either be too low or too high and the tool will push the float down. Remove the float and bend the tab whatever way you need to and recheck the height.
I've taken a pic but only on my phone so can either email it too you if you pm me your email or I can post here later.
- speedy231278
Later will be fine, I *still* have no idea when my fuel pipe o-rings will arrive..
http://www.factorypro.com/tech_tuning_p ... edure.html
Like this (tilting the carb until the float drops in and doesnt compress the pin)
And yes DM the float height on the 35 is 12.something :)
