Creamy oil
- One Hit Wonder
Creamy oil
The bike rides fine ,but i have a slight creamy mixture in my oil cap,
what causes it,help please ?
- thunderace
- Bike owned: R6, YZF600R
Re: Creamy oil
Possible head gasket failure. How's it running temperature wise?
Re: Creamy oil
coolant mixing with oil end up like mayonaise. Usually head gasket failure, or waterpump seal.
Its nasty stuff and can be corrosive so drain asap. Whip the head off and get it checked for flatness
Re: Creamy oil
If your bike is running absolutely fine then it's most likely coolant getting in and not head gasket failure although check both, better to be safe than sorry :)
- thunderace
Re: Creamy oil
Joshh wrote:If your bike is running absolutely fine then it's most likely coolant getting in and not head gasket failure although check both, better to be safe than sorry :)
Six months late
- vfrman
- Bike owned: NC30, 1098s
Re: Creamy oil
And to keep this zombie topic going....
How much cream we talking about here? If you let a bike sit for a long time in a damp climate (the UK!) water condenses in the oil and can leave a creamy residue on the cases. If it is a lot of cream, then yeah, big problems.
- Bike owned: ZXR 400 L4, FZR 1000 EXUP '89
Re: Creamy oil
^ what he said, a little in the cap is nothing to worry about, if you drained the oil and it was ALL like that...then you have a problem.
it will just be cool air (remember there is a two-way breather pipe from the crankcases to the airbox/outside air) thats mixed with a small amount of oil.
