Will NC35 Pistons fit without modification in CB-1
bbanna
Post by bbanna » Mon Aug 06, 2012 6:48 pm
Recently I have found that some CB-1 racers have put NC29 pistons in their bikes to up the compression a bit. Then I was told that some NC29 racers have put NC35 pistons in their bikes to up the compression. So it was suggested that I skip the NC29 and go for the NC35 pistons. The cost is the same for either set.
The NC29 pistons are a drop in to the CB-1 without any valve clearance modificatons. So my question is would the NC35 pistons be drop into the CB-1 as well without having to do any modifications?
Brian
Re: Will NC35 Pistons fit without modification in CB-1
Post by CMSMJ1 » Mon Aug 06, 2012 10:21 pm
they are the same pistons I reckon
Only some of the 29 pistons (later bikes) are the higher comp..
Happy to be educated on it..but that is my understanding
CB1 race bike? Lets see it!
bbanna
Post by bbanna » Tue Aug 07, 2012 12:38 am
This is the best CB-1 race bike I have ever seen. If I were to build my CB-1 into a race bike, I would copy this one. This is where I saw the NC29 pistons being used.
http://home.planet.nl/~boerl060/cb1-rE.htm
Brian
petrolhead19
Bike owned: 2 x nc23's 1 x nc29
Post by petrolhead19 » Tue Aug 07, 2012 12:50 am
should fit no problem, cb1 engines are practically same as nc23's and have seen nc35 pistons in 23's
So dont think there will be a problem
Post by CMSMJ1 » Tue Aug 07, 2012 8:59 am
bbanna wrote:This is the best CB-1 race bike I have ever seen. If I were to build my CB-1 into a race bike, I would copy this one. This is where I saw the NC29 pistons being used.
Brian
Cool - have met these guys..they cam to the 400Greybike trackday at Cadwell in 2008? ish..
