ZXR Dynojet kit...running rough.
Hellmutt
Post by Hellmutt »
Question for you tuning guru's....Bought a dynojet kit for my ZXR, installed it as instructed and the bike started and idles great. Only problem is as I'm riding it there is a mumur when I am not on the gas, and at times the throttle is not as responsive as it was before. I can definately feel the power increase but the unreponsiveness and murmur are killing me..Any help would be great...I did put spacers on the needles and added end cans and K&N filter.
Joshh
Re: ZXR Dynojet kit...running rough.
Post by Joshh »
It could be just something really simple like your air/fuel ratio could be wrong to how it should be running when lower down. Try getting your air/fuel ratio checked you can do that on a dyno & tweek your dynojet kit a little, see if this makes any difference.
#EDIT - Because your running K&N air filter and a aftermarket exhaust you need to tweek your dynojet kit to co-operate with these, as running them straight in are intended for stock filters & exhausts
