Sprocket and chain sizes
iArGod
Hi guys
I wanted to up the teeth on my rear sprocket for my nc30 to 43/44; i dont know much about the subject but understand ill need a new chain to accommodate the new sprocket.
How do i know what chain i need for a different sized sprocket?
Anything else i should know on the matter?
Keir
Keir
Re: Sprocket and chain sizes
What sized sprockets (front and rear) do you have on it now? The number of teeth is usually stamped on them.
If you have standard sizes fitted (15t front, 40t rear) it would be easier to go to a 14t front because you won't need a new chain then and it gives a similar gear ratio to upping the rear to 43/44.
Just make sure that whatever new sprocket you buy is the same pitch as what's already on there. 525 is standard, but many will have been fitted with 520, again it's usually stamped on the sprockets.
HTH
HTH
Also - 43 is fine, 44 is bloody tight and you get a lot less adjustment for a slack chain as the sprocket will hit the swinger.
If you are on std 15t front then get a 14t...easier and cheaper!
Saying that, you should really be getting the chain and sprox in a set..
apaulette_86
what is the best sprocket size for trackday and racing for the nc35?....
It depends a bit on the track, I used to like 14 front and 40 rear on my track bike with rvf gearbox.
NC 35 owners
hi CAMMO what front and rear sprocket size will you recommend for me for road standard RVF NC35..as now I'm using standard front 15 and rear 38 ..its feel like the bike has no power on 6th gear..can you please advice me on this..
many thanks
many thanks
- Speedy
- Bike owned: RVF400RR, ER6n
Try 14/38 or 15/40, of 520 pitch.
A 14T front sprocket is the equivalent to 3 more teeth at the rear.
Less teeth = less weight, it may be by a small amount but it'll help the engine to 'pick up' faster; the 520 pitch is also lighter than the standard 525.
