samco hoses
wedge
samco hoses
i know there someone selling samco hoses for the rrsp model on ebay and i know there is an extra hose the rrsp kit because of the oil cooler........i take the two other rad hoses are the same as the standard 3tj rr model???...or does someone else know of a website selling them because i will not have phone reception for couple of days(working up in the hills)but do get the net and i want to oreder them asap..
rockTJ
Re: samco hoses
I hope their kit for the RRSP is better than the std 3TJ. On that kit the water pump to rad hose is about 50-70mm too short. I will stick in a complaint to Samco once I get back from holiday. I will have to get a length of 22mm straight silicone to make my own up........
Chris
Chris
Re: samco hoses
If you really want samco hoses then it could be better to measure the overall length, get some of their flexible hose and cut your own.
rockTJ
Re: samco hoses
The S-shaped hose on the right of the engine is a perfect fit. There is no way you could make a length of straight hose look as 'meant for the job' as the one they supply. The 90 degree corners are too small radius to do neatly.
Chris
Chris
