Seized Bearing Holder - Adjusting Chain
Haley
Hello,
Fitting a new chain and sprocket onto my NC30, the bearing holder is seized and will not allow for adjustment i.e.it will not rotate... Ideas?
Halet
Halet
GFRacingUK
Re: Seized Bearing Holder - Adjusting Chain
what are you using to move the adjuster? The correct Honda specific spanner is required, its probably just not been moved for a long time. Dont be tempted to use a screwdriver and hammer to move it though.
GF Racing UK - New & Used Parts CBR400 NC23/NC29/VFR & RVF400 NC30/ NC35
Contact: Dan Marsden or Graeme France
http://www.gfracinguk.com
sales@gfracinguk.com
Tel: 01652 650142 -
Ext 1 for Parts - Dan
Ext 2 for Workshop - Graeme
Tel: 01652 650142 -
scooble
when I got my NC30, mine was siezed too. I had to remove the (siezed) rear wheel, then the big circlip and bash it out wit a hammer. The cavity it sat in was full of gravel. I cleaned out the gravel, installed a new greased hub and the whole thing moves smoothly now.
oldgreyandslow
- Bike owned: 1990 NC30
scooble wrote:when I got my NC30, mine was siezed too. I had to remove the (siezed) rear wheel, then the big circlip and bash it out wit a hammer. The cavity it sat in was full of gravel. I cleaned out the gravel, installed a new greased hub and the whole thing moves smoothly now.
As he says, well about the gravel etc anyway.
Clean it out, I was surprised how much gravel and shite was in there when I did mine, and put some expanding foam in the swaing arm so it doesn't fill up again. Put a smear of grease on the outside of the bearing holder, reassemble and that should sort it.
Haley
Cheers for the advice, I'll have to get hold of an auxiliary stand before I give it a go, but I'll keep you informed of my progress
