fork oil
bullitt
- Bike owned: vfr400 nc21
fork oil
hi guys
im renewing my front fork oil which oil do i use
there are two bottles that i can see one says 10w
the other says 10w synthetic both castrol
plus can anyone tell me what the black dial is
on bottomn left hand fork it is round there are nos 1 to 4
what number should i have it on
many thanks
many thanks
- Bike owned: VFR400
Re: fork oil
Another contributor to this site, Neosophist, has provided this info to another member with a NC21.
Right Fork: 340cc
Left Fork: 345cc
Weight: 10-W
The dial at the bottom of the left fork leg is for the anti-dive setting. This is the reason for slightly more oil in the left fork. Bigger number equals less dive under brakes. What setting you use really depends on how you want the bike to performs under braking.
Regarding Castrol 10W vs synthetic, synthetic is generally considered a superior product but in this case you need to be aware that 10w synthetic Castrol is about 3x thicker than non-synthetic 10W Castrol. Having said that, your damper rod forks would probably be better suited to the thicker synthetic Castrol, rather than the thinner non-synthetic oil.
Hope this helps.
Right Fork: 340cc
Left Fork: 345cc
Weight: 10-W
Hope this helps.
Re: fork oil
Yep for NC21.magg wrote:Another contributor to this site, Neosophist, has provided this info to another member with a NC21.
Right Fork: 340cc
Left Fork: 345cc
Weight: 10-W
Hope this helps.
Not seen an adjuster before? Picture? Are they NC21 forks?
MB James
- Bike owned: Honda VFR400R NC21&NC24
Re: fork oil
Hi. I am refurbishing my shocks this week. Will send you a picture.
My concern is maybe restretching the springs to get the set stiffness back again. is this advisable?
any other ideas?
I weigh about 103kg's
any other ideas?
