NC35 - AFAM Sprocket Question
Pete Diggs
Bike owned: NC35, Monster S4R, MG 850T
Post by Pete Diggs »
Hey Guys,
I'm installing a 15 tooth AFAM front sprocket on my RVF.
However it looks like one side towards the center is wider than the other.
Does the wider side face out or the shorter one?
Thanks for your help!
ibby4585
Bike owned: SP's
Re: NC35 - AFAM Sprocket Question
Post by ibby4585 »
I'm pretty sure the 35 is the same as the 30 and the larger shoulder and writing sits on the outside.
Kris
kevprojex
Bike owned: ktm200exc gsxr400gk71b sv650
Post by kevprojex »
Normaly if it is stamped with numbers they face outwards.
Speedy
Bike owned: RVF400RR, ER6n
Post by Speedy »
Don't wish to confuse things, but the O.E. sprockets come with equally sized shoulders, in which case the Afam wider shoulder should face in, so as to offset it as per standard?
Here's a pic off David Silver that may help decide:
kevprojex
Post by kevprojex »
If its a 520 conversion front sprocket the wider sholder will face outwards 525 pitch looks even.
Pete Diggs
Awesome...thanks for the help!
Speedy
Post by Speedy »
kevprojex wrote:If its a 520 conversion front sprocket the wider sholder will face outwards 525 pitch looks even.
Ah yes, it does make sense if the pitchs are different!
Cheers.
Lane
Bike owned: MC21,MC22,NC35's,VJ22
Post by Lane »
If in doubt, sit it on the spline in both directions and peer down the line from the rear sprocket, you will be able to tell the correct orientation from this perspective.
