Carb Vent Hose Routing GK76
				rgvsp
Can someone remind me the correct routing on the carb vent hoses I have the screw driver on.  Do they go in between the other two hoses, like I have them here or do they point out the front and then wrap around back?  Is it correct that they just lay on top of the airbox on a standard 76?
- Variablevalves suck
Re: Carb Vent Hose Routing GK76
They are ok as set and just lay over the r/h top side of the air box, should be a little clip on the box that holds them.
