Headstock stand
Tomzed
- Bike owned: Yamaha wr125x and Nc30
Headstock stand
What size pin is needed on a headstock stand for an nc30
lukemillar
Re: Headstock stand
I'll measure my headstock pin tonight if no else replies before then
- VFRkieran
Re: Headstock stand
27 mil mate.
hakan
- Bike owned: NC35, Ninja 250R
Re: Headstock stand
Is it the same for an RVF?
I got a 27mm pin and it doesn't fit. Unless the one I got is incorrect?
- VFRkieran
Re: Headstock stand
The RVF has diffrent yokes so id imagine its a diffrent size mate, unfortunatly i dont have an RVF so i cant measure for you.
GFRacingUK
Headstock stand
the RVF pin is much smaller than the NC30, I'm not at home so can't measure it
GF Racing UK - New & Used Parts CBR400 NC23/NC29/VFR & RVF400 NC30/ NC35
Contact: Dan Marsden or Graeme France
http://www.gfracinguk.com
sales@gfracinguk.com
Tel: 01652 650142 -
Ext 1 for Parts - Dan
Ext 2 for Workshop - Graeme
Tel: 01652 650142 -
hakan
Re: Headstock stand
That's alright guys.
Would it be in the Haynes manual at all?
I could measure mine with a ruler or something but I'm guessing it wouldn't be accurate enough when we're talking mm's.
- VFRkieran
Re: Headstock stand
I couldnt find it in the haynes when i looked, could try with a ruler or go down to a bike mechanic and ask to borrow thier pins for 5 minutes so you can see what size it is.
hakan
Re: Headstock stand
I looked in the Haynes too but couldn't see it.
I have tried with a ruler and it looks to be about 24mm but I cannot be exact.
The 27mm pin I have is just off, so I think the next common size down would be it.
I might just have to order a 24mm and see how I go.
- mo haggs
- Bike owned: bikeless
Re: Headstock stand
i have a biketek stand that came with 4 pins 13mm, 15mm, 16.5mm + 18mm.
i use the 18mm, it's not a tight fit but it doesn't need to be - in fact it's prob better to be a bit loose so you can easily move the stand into position
