Light switch
Tomzed
Bike owned: Yamaha wr125x and Nc30
Light switch
Post by Tomzed »
Just realised I ordered an nc35 light switch instead of an nc30 is there any reason this won't work on an nc30 I see the difference is there's no switch to turn the lights on
Re: Light switch
Plugs may be different, no doubt some extra relay to control auto-lights on with igntion.
Can't see it being plug and play.
My Jap spec ZXR400 had auto-lights, the UK version had a switch, you couldn't retro-fit the Jap (auto lights) switch to the UK bike without extra bits.
Might be wrong on the NC30/35 but if you can get the proper one i'd do that.
hardnutdvd
Regular Member
Bike owned: RVF400 NC35
Re: Light switch
Post by hardnutdvd »
are you talking about the left hand switchgear?
if so they are different and wont be plug and play...
Tomzed
Re: Light switch
Post by Tomzed »
Yes the left hand is the right hand the same
hardnutdvd
Regular Member
Re: Light switch
the left hand switchgear has all the functions. lights, horn, indicators and flash.. right hand switchgear has kill switch..
has your left hand one just stopped working??
if so you might want to check the headlight bulbs before you replace the switchgear, cos if your running 60/55 watt bulbs on an imported bike without the relay mod. the same thing will happen again.
i have a rough left hand switchgear, i dont even know if it works (no reason why it shouldn't though)
you can have it if you need it...
Tomzed
Re: Light switch
Post by Tomzed »
No mate it's a bike I'm building I just bought the switch gear because it was in good condition. And realised it was nc35 stuff when it got here
hardnutdvd
Regular Member
Re: Light switch
ah ok, fair enough. :)
Bike owned: VFR400
Re: Light switch
Post by magg »
Not plug and play and a lot of work to rewire.
