Strange NC30 symptoms
- ibby4585
- Bike owned: SP's
Had a long ride on a NC30 yesterday and it behaved differently to any I have rode before.
There were no holes in the rev range and it was quite clean through the gears, but as soon as I let off the throttle the engine basically shut off.
It made the power very 'on' 'off' awful in lower gears.
Not sure when the bike was serviced or any history of it. I've literally checked the oil and stuck some fuel in as yet.
Symptoms sound familiar?
Kris
Kris
Re: Strange NC30 symptoms
pilots jets dirty or screws poorly adjusted?
porndoguk wrote:pilots jets dirty or screws poorly adjusted?
sounds about right ^^
- ibby4585
- Bike owned: SP's
I will obviously clean the carbs up but I thought If it was fuel/carbs it would be more unpredictable and fluffy low revs.
Will have a root about
Is it standard or had larger jets fitted?
- ibby4585
- Bike owned: SP's
I don't know mate haven't stripped it yet, but I don't think it's carbs to be honest.
Ok, it's just that i have 2 bikes, one standard and one fitted with larger jets........the latter on throttle shut off slows down mega quick......V engined bikes do typically slow right down when the throttle is closed but then we are all aware of that
The only other thing i can think off is fuel delivery, ie the tap
- ibby4585
- Bike owned: SP's
Will have a look at it and strip it down it probably hasn't been serviced for years.
also this ^^^^ as the revs drop as does the level of vacuum created by the inlet tract,vfrderek wrote:Ok, it's just that i have 2 bikes, one standard and one fitted with larger jets........the latter on throttle shut off slows down mega quick......V engined bikes do typically slow right down when the throttle is closed but then we are all aware of that![]()
could be a number of things but it will be simple, kris youve probally had carbs off more times than me with the ammount of NCs youve owned,
- ibby4585
- Bike owned: SP's
Yeah done it a few times lol. I thought it could be damaged throttle cables or routed wrongly.
