rev booster electronic box?
vfr400aussie
Post by vfr400aussie »
Hi
im trying to find the electircal problem on my bike found a wire disconnected in this rev booster thing
which just looks like an add in between the cdi unit.
i will bypass it tomo and see what happens but does anyone have one??
[img]2012-06-12_20-08-36_775[/img]
Re: rev booster electronic box?
it is not a revbooster.
it will be to prevent the 180kmh restriction kicking in. Nothing at all will happen if you remove it..unless you leave the clocks unplugged and then you will get the 5.5k limp home problem.
vfr400aussie
um well i dont have a speedo on it as its a track bike so that means i better fix the wire and plug it back in
Aye, you need it if no speedo.
You can also do the de restrict witha 2.2k resistor - have a look in the docs area
