Page 1 of 6
strange noise problem, (video)
Posted: Sat Jun 09, 2012 7:44 pm
by xivlia
yesterday when i went to ride my bike, i noticed while going the bike was making strange rattling noises. i knew it was the chain, it was very slack. so i adjusted the chain, but the problem is still there... it sounds like something is grinding, and it is coming out where the speedo cable connects into. which i assume is the front sprocket? any idea why it is making this stupid noise?
http://s911.photobucket.com/albums/ac31 ... EO0006.mp4
Re: strange noise problem, (video)
Posted: Sat Jun 09, 2012 7:50 pm
by porndoguk
chain TOOOOOOOOOOOOOOO tight!
Posted: Sat Jun 09, 2012 7:51 pm
by porndoguk
porndoguk wrote:chain TOOOOOOOOOOOOOOO tight!
Sorry
CHAIN TOO FUCKING TIGHT!
by xivlia
hmm. but the slack meets the haynes requirements. its between 15-25mm.. :|
:P i will check it again then, but im pretty sure i measured it right.
Posted: Sat Jun 09, 2012 7:56 pm
by porndoguk
Video the slack, movement,
that sounds like a classic tight chain, however it could be a stuck link, how well and often do you lube, what are the condition of the sprocket teeth, how old is the chain
Posted: Sat Jun 09, 2012 7:57 pm
by Deviant400
speedo drive unit / bush / cable
by porndoguk
Deviant400 wrote:speedo drive unit / bush / cable
cant be, jim, look at the video again its been removed ;)
Posted: Sat Jun 09, 2012 8:17 pm
by xivlia
well the chain and sprockets i have not touched. so i have no idea how old they are... i do lube with chain oil every so often, but i can see some rusty links. i will make a video of the slack in an hour or so.
Posted: Sat Jun 09, 2012 8:27 pm
by xivlia
okay, here is the slack video, sorry for moving the cam about, the stupid exhaust pipe is in the way... i hope you can get an approximate reading from it.
http://s911.photobucket.com/albums/ac31 ... EO0007.mp4
Posted: Sat Jun 09, 2012 8:33 pm
by Deviant400
my bad , didnt notice :oops:
