Have to bump start
				Haydn2613
Have to bump start
Hi guys yesterday my bike started first time without any problems. Now however it wont start using the button and it even backfired once (christ that was loud). But however i had to get to work so I tried bumping it and low behold it starts up first time with that little bit of motivation.
When it is nice and warm it will start up using the starter button but not when its cold anymore.
Any suggestions to what might have happened in one night?
- Variablevalves suck
Re: Have to bump start
Give the spark plugs a clean and see if it helps.
				dobbslc
It could be the battery is on it's way out, the cold engine cranking over will take enough power away from the cdi / coils etc to give a poor spark and these bikes have a very marginal ignition system to start with!
When you bump start you have all the battery power just for the ignition system so it can start more easily.
New plugs do make a big difference to starting so might be worth a go.
Dobbs
Dobbs
				Haydn2613
Well i checked the battery and had a reading of 13.3v so i guess its time to check the plugs
				morris147
Have you taken a reading of the battery when the ignition is on?Haydn2613 wrote:Well i checked the battery and had a reading of 13.3v so i guess its time to check the plugs
				Haydn2613
12.8v and the plugs seem fine...sigh anyone had trouble with the starter motor before? Because i'm starting to suspect it
				Jaicen
- Bike owned: GK76SP & ER6F
If it turns over on the starter, I'd look at the coils first. Also check for any dodgy wiring or corroded connectors.
