Page 1 of 2
RVF CDI Pinout
Posted: Sun Jun 03, 2012 2:42 am
by Fry
Hi guys,
I've got an HRC CDI here for an RVF400, but no wiring loom for it. I just want to do a bench-test to check it's all working before I track down the plug.
Does anyone have a pinout scheme for it?
Re: RVF CDI Pinout
Posted: Sun Jun 03, 2012 5:06 am
Fry wrote:Hi guys,
The RVF ignition box plugs into the standard loom?
The NC30 required the HRC kit loom to use.
Re: RVF CDI Pinout
Posted: Sun Jun 03, 2012 7:48 pm
by fontyyy
The RVF HRC cdi does indeed work with the stock loom, the side stand down/in gear cut out switch stops working but that is all.
Re: RVF CDI Pinout
Posted: Mon Jun 04, 2012 4:53 am
by Fry
My bad. Should have been clearer. The bike i've got here is a VFR400, so it has the two plugs coming off the wiring loom, not the RVF connector.
The wiring diagrams I have show the colour scheme, but not the pin locations. I just want to bench test it before I shell out for an RVF loom.
Re: RVF CDI Pinout
Posted: Mon Jun 04, 2012 6:15 am
by Cammo
The easiest way to test it is to try it on another rvf.
Are you putting it on a vfr? If so you need the loom, rvf iginition pick up and an rvf tacho also.
Where are you located?
Re: RVF CDI Pinout
Posted: Mon Jun 04, 2012 7:01 am
by Fry
In Australia. Right in the middle of nowhere.
I've got the pickup and RVF wheel, and am using an Ecliptech electronic tacho.
I'm going to run it in parallel with a Megasquirt injection system I'm building.
I just didn't fancy buying a complete loom fro one connector, only to find out it was toast.
Re: RVF CDI Pinout
Posted: Mon Jun 04, 2012 7:18 am
Fry wrote:In Australia. Right in the middle of nowhere.
I seem to remember a post where somebody switched back to using the stock ignition over the HRC ignition as it was better, perhaps it was Cammo?
Re: RVF CDI Pinout
Posted: Mon Jun 04, 2012 8:14 am
Porndog had a thread with some back to back results
If I was going to whole hog with injection (have you looked at the threads by Mruehl, Lasse and Mike Norman) then I'd use ignitech to give some adjustability
Re: RVF CDI Pinout
Posted: Mon Jun 04, 2012 8:36 am
by Fry
Thanks guys. I'll check out those threads and the ignitech, I'm just doing this one on a budget.
Even if I don't use the CDI, I'd like to test it and see if it's still good before I sell it on.
Re: RVF CDI Pinout
Posted: Tue Jun 05, 2012 5:13 am
by Fry
Got a guy from another forum checking out his spare loom for me when he gets a chance. I'll post the scheme on here in case it can help anyone else.
