RVF400 Neutral light problem
Andy_Edw
My neutral light on my nc35 flickers on & off when its in neutral, So i can't leave the bike running while on its stand because it thinks its in gear
Any suggestions?
Andy
Any suggestions?
Andy
Re: RVF400 Neutral light problem
clean the neutral switch connectors...
Andy_Edw
Where are they located?
err..down near the gearbox - right hand side if I remember ! Near the dipstick
Mavirick
- Bike owned: NC35
Change the bulb
Andy_Edw
I checked all the wires, They were all fine
Can you even change the bulbs lol?
- ibby4585
- Bike owned: SP's
You sure you got the right wire? It's a single spade end connectors thats really tight against wire easily to dislodge.
- hannakournikova
Check clutch diode with working one. It's lhs sitting on the bike behind arse
- Bike owned: VFR400
Check that neutral switch gives consistent ground signal by measuring its resistance to chassis with a multimeter while the engine is running.
