NC24 oil Change - Oil filter the same as NC30?
Hi
More questions.
Is the NC24 oil filter the same as the NC30?. If not does anyone know a part number.
More questions.
Re: NC24 oil Change - Oil filter the same as NC30?
wemoto and david silver spares keep all the parts.
http://www.wemoto.com" onclick="window.open(this.href);return false;
http://www.davidsilverspares.co.uk" onclick="window.open(this.href);return false;
Dave silvers will also tell you the part numbers so you can look up the filter for each and check.
Thanks for the reply, it does look as if the NC24 and NC30 filter are the same.
That makes it easy.
That makes it easy.
Hi all I would just double check about my statement about nc24 and NC30 are the same oild filter, I think I could be wrong.
no - you are right. HF303 if a hiFlo or a Champion F 301 or 306. -as far as I can find out in 2 mins of looking..
pretty much a standard fitment - best bet, mail Rick Oliver and he will sort you one out as he is the man for your VFR (and also happens to work at a Honda dealers...)
